メインコンテンツにスキップ
Motorola V276 Motherboard Replacement
必要な工具と部品
  1. Motorola V276 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Motherboard Replacement: 手順 2、 1の画像 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Motherboard Replacement: 手順 3、 2の画像 1 Motorola V276 Motherboard Replacement: 手順 3、 2の画像 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
  5. Motorola V276 Motherboard Replacement: 手順 5、 1の画像 1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
  6. Motorola V276 Motherboard Replacement: 手順 6、 3の画像 1 Motorola V276 Motherboard Replacement: 手順 6、 3の画像 2 Motorola V276 Motherboard Replacement: 手順 6、 3の画像 3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Motherboard Replacement: 手順 7、 3の画像 1 Motorola V276 Motherboard Replacement: 手順 7、 3の画像 2 Motorola V276 Motherboard Replacement: 手順 7、 3の画像 3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
  8. Motorola V276 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently peel back the motherboard from the main part of the phone.
終わりに
作成者
8人の作成者と共同で作成されました。
Jonathan Cheung
メンバー登録日: 04/11/10
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G96
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,061
