メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola V276 Keypad Replacement
必要な工具と部品
  1. Motorola V276 Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola V276 Keypad Replacement: 手順 2、 1の画像 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola V276 Keypad Replacement: 手順 3、 2の画像 1 Motorola V276 Keypad Replacement: 手順 3、 2の画像 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola V276 Keypad Replacement, Motherboard: 手順 4、 1の画像 1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola V276 Keypad Replacement: 手順 5、 1の画像 1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola V276 Keypad Replacement: 手順 6、 3の画像 1 Motorola V276 Keypad Replacement: 手順 6、 3の画像 2 Motorola V276 Keypad Replacement: 手順 6、 3の画像 3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    FixBotに聞いてみる
    コメントを追加
  7. Motorola V276 Keypad Replacement: 手順 7、 3の画像 1 Motorola V276 Keypad Replacement: 手順 7、 3の画像 2 Motorola V276 Keypad Replacement: 手順 7、 3の画像 3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
    FixBotに聞いてみる
    コメントを追加
  8. Motorola V276 Keypad Replacement: 手順 8、 1の画像 1
    • Gently peel back the motherboard from the main part of the phone.
    FixBotに聞いてみる
    コメントを追加
  9. Motorola V276 Keypad Replacement, Keypad: 手順 9、 1の画像 1
    • Peel back keypad starting from the top of the phone
    • You can clean or replace the keypad once you have removed it from the phone
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Jonathan Cheung
メンバー登録日: 04/11/10
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G96
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 1,213
