はじめに
Replacing the phone's headphone jack.
必要な工具と部品
Locate the silver button on the back of the phone, near the bottom.
Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
Note the metal connections on the phone, which are now exposed with the battery removed.
There are corresponding metal connectors on the replacement battery.
When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Use Spudger to remove rubber plug from upper left corner of the back of the phone
