この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The circuit board is the connecting point of all components in the radio. If the circuit board is malfunctioning, the radio will not function until the circuit board is replaced. Follow the steps below to properly replace the circuit board of the radio.
必要な工具と部品
To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
ある他の人がこのガイドを完成しました。
