はじめに
The battery terminals are the contacts between the battery and the radio and guide the electricity from the battery to the radio. Without properly functioning battery terminals, power cannot be supplied to the radio. Follow the steps below to properly replace the battery terminals.
必要な工具と部品
Now the circuit board can be removed from the back faceplate.
To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
Once the faulty leads are removed, you can insert the new leads. To reassemble your device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
Gostaria de saber se eu tenho como encontrar a placa para fazer a troca, tenho um rádio da Motorola t400
mauropessoa - 返信
