このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Using a T6 Torx Screwdriver, remove the four (4) T6 2 mm Torx screws that are securing the rear metal plate.
Apply moderate pressure with the screwdriver and rotate it counterclockwise to loosen the screw.
Ensure that you keep track of the screws and return them to their original positions once the repair is finished.
この手順は未翻訳です。 翻訳を手伝う。
At the bottom of the phone near the speaker, use the iFixit Opening Tool to remove the black plastic screw cover.
Some force is required as the cover is attached by several clips. The first clips will be the hardest to dislodge.
Under the cover are round plastic pieces that cover the microphone. Be careful not to lose them.
この手順は未翻訳です。 翻訳を手伝う。
Now turn the phone over. Insert the iFixit Opening Tool between the frame and the outer case on the side of the phone.
Apply pressure using the iFixit Opening Tool to pry the case apart. Some force is required as the frame is attached by several clips. The first clip will be the hardest to dislodge.
As soon as the first clip is dislodged, work the tool around the entire edge of the phone to carefully remove the remaining clips. This will avoid breaking the frame.
Once the frame is completely separated from the outer case, remove the top numerical layer of the keypad by lifting it up.
2 の人々がこのガイドを完成させました。
