メインコンテンツにスキップ
Motorola SURFboard SB5101 Outer Cover Replacement
必要な工具と部品
  1. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 1 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 2 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 手順 2、 3の画像 1 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 手順 2、 3の画像 2 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 手順 2、 3の画像 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 手順 3、 3の画像 1 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 手順 3、 3の画像 2 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 手順 3、 3の画像 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
終わりに
In order to learn how to re-assembly your device, visit the Reassembly Guide.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Bhavik Patel
メンバー登録日: 10/13/14
276 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-2, Benson Fall 2014 Clemson, Team 1-2, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 1,148
