はじめに
Removing the motherboard is necessary if the motherboard itself or components of the motherboard need to be accessed or replaced.
必要な工具と部品
Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
Remove the screw and set aside.
Locate the two horizontal slots on the bottom of the device.
Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
Repeat with the other slot to completely unlock the device.
Grab the top and the bottom of the device and gently pull the device open.
Continue pulling until you have completely removed the top cover of the device.
After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
To replace the motherboard, follow these instructions in reverse order.
6 の人々がこのガイドを完成させました。
