メインコンテンツにスキップ
Motorola SURFboard SB5101 Motherboard Replacement
必要な工具と部品
  1. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 1 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 2 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Screw on the Back of the Device: 手順 1、 3の画像 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: 手順 2、 3の画像 1 Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: 手順 2、 3の画像 2 Motorola SURFboard SB5101 Motherboard Replacement, Unlocking Router: 手順 2、 3の画像 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: 手順 3、 3の画像 1 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: 手順 3、 3の画像 2 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Cover: 手順 3、 3の画像 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Motherboard Replacement, Grabbing the Motherboard: 手順 4、 2の画像 1 Motorola SURFboard SB5101 Motherboard Replacement, Grabbing the Motherboard: 手順 4、 2の画像 2
    • After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
  5. Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: 手順 5、 3の画像 1 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: 手順 5、 3の画像 2 Motorola SURFboard SB5101 Motherboard Replacement, Removing the Motherboard: 手順 5、 3の画像 3
    • Slowly lift the motherboard out of the case.
終わりに
To replace the motherboard, follow these instructions in reverse order.
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Cayce Rast
メンバー登録日: 10/13/14
421 ポイント
3のガイドは作成済み
チーム
Clemson, Team 1-2, Benson Fall 2014 Clemson, Team 1-2, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 6,625
