メインコンテンツにスキップ
Motorola Razr V3m Speaker Replacement
必要な工具と部品
  1. Motorola Razr V3m Speaker Replacement, Battery: 手順 1、 2の画像 1 Motorola Razr V3m Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Speaker Replacement: 手順 2、 2の画像 1 Motorola Razr V3m Speaker Replacement: 手順 2、 2の画像 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Speaker Replacement, SIM Card: 手順 3、 2の画像 1 Motorola Razr V3m Speaker Replacement, SIM Card: 手順 3、 2の画像 2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Speaker Replacement, Antenna: 手順 4、 2の画像 1 Motorola Razr V3m Speaker Replacement, Antenna: 手順 4、 2の画像 2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Speaker Replacement: 手順 5、 1の画像 1
    • Carefully use a plastic opening tool to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Speaker Replacement: 手順 6、 2の画像 1 Motorola Razr V3m Speaker Replacement: 手順 6、 2の画像 2
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Speaker Replacement: 手順 7、 1の画像 1
    • Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
  8. Motorola Razr V3m Speaker Replacement: 手順 8、 2の画像 1 Motorola Razr V3m Speaker Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to pry the edge of the antenna away from back panel.
    • The antenna may be fastened with two grey clips on either side. If this is so, unfasten two plastic clips located on the edge of the antenna.
    • Lift antenna away from back panel.
  9. Motorola Razr V3m Speaker Replacement, Speaker: 手順 9、 1の画像 1
    • The Speaker is the round piece located beneath the antenna.
    • Use tweezers to remove the speaker.
終わりに
作成者
1人の作成者と共同作成されました。
Daniel Simcock
メンバー登録日: 10/24/15
731 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015人のメンバー
UMASSD-SHASTANY-F15S3G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 246
