メインコンテンツにスキップ
Motorola Razr V3m Keypad Cover Replacement
必要な工具と部品
  1. Motorola Razr V3m Keypad Cover Replacement, Battery: 手順 1、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement, Battery: 手順 1、 2の画像 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Keypad Cover Replacement: 手順 2、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 2、 2の画像 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Keypad Cover Replacement, SIM Card: 手順 3、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement, SIM Card: 手順 3、 2の画像 2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 手順 4、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 手順 4、 2の画像 2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Keypad Cover Replacement: 手順 5、 1の画像 1
    • Carefully use a metal spudger to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Keypad Cover Replacement: 手順 6、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 6、 2の画像 2
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Keypad Cover Replacement: 手順 7、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 7、 2の画像 2
    • Use a T6 Torx bit screwdriver to remove the two screws holding the cover down.
    • The metal shield will come off with the screws; don't forget to reattach it before replacing the screws.
  8. Motorola Razr V3m Keypad Cover Replacement: 手順 8、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 8、 2の画像 2
    • Remove the keypad cover, located below the keypad on the front of the phone.
  9. Motorola Razr V3m Keypad Cover Replacement: 手順 9、 2の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 9、 2の画像 2
    • Remove the sticker on the back of the phone.
  10. Motorola Razr V3m Keypad Cover Replacement: 手順 10、 3の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 10、 3の画像 2 Motorola Razr V3m Keypad Cover Replacement: 手順 10、 3の画像 3
    • Using a plastic opening tool, push the four metal tabs along the edge of the phone in towards the keypad.
  11. Motorola Razr V3m Keypad Cover Replacement: 手順 11、 3の画像 1 Motorola Razr V3m Keypad Cover Replacement: 手順 11、 3の画像 2 Motorola Razr V3m Keypad Cover Replacement: 手順 11、 3の画像 3
    • Using the plastic opening tool, pry the edges of the keypad until it is loose. Then, pull it off.
    • It is easiest to work your way from left to right when loosening the case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jonathan Gendron
メンバー登録日: 10/28/15
122 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015人のメンバー
UMASSD-SHASTANY-F15S3G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 1,058
