はじめに
This guide will show you how to remove and replace the speaker for a Motorola V3c.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Unscrew the two screws in the back using the T6.
    • Unscrew the two screws in the back using the T6.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  6. Peel off the connector between the motherboard and the body of the phone.
    • Peel off the connector between the motherboard and the body of the phone.
  7. Pull out the two black rubber covers using tweezers. The second rubber cover is much harder to get out.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  8. Pull out the white plastic cover by unclipping the two plastic pieces shown. Pull out the white plastic cover by unclipping the two plastic pieces shown.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  9. Pull out the speaker.
    • Pull out the speaker.
まとめ
Joshua Ruehlig
メンバー登録日: 2010年01月14日
503 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G4
3 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 5,280
