メインコンテンツにスキップ
Motorola Razr V3c Screen (CDMA) Replacement
必要な工具と部品
  1. Motorola Razr V3c Screen (CDMA) Replacement, Upper Casing (CDMA): 手順 1、 1の画像 1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Screen (CDMA) Replacement: 手順 2、 1の画像 1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Screen (CDMA) Replacement: 手順 3、 1の画像 1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Screen (CDMA) Replacement: 手順 4、 3の画像 1 Motorola Razr V3c Screen (CDMA) Replacement: 手順 4、 3の画像 2 Motorola Razr V3c Screen (CDMA) Replacement: 手順 4、 3の画像 3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  5. Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 手順 5、 2の画像 1 Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 手順 5、 2の画像 2
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
  6. Motorola Razr V3c Screen (CDMA) Replacement: 手順 6、 1の画像 1
    • Remove small black sticker covering the camera ribbon connector.
  7. Motorola Razr V3c Screen (CDMA) Replacement: 手順 7、 1の画像 1
    • Flip over small hinge that covers the camera ribbon connection.
  8. Motorola Razr V3c Screen (CDMA) Replacement: 手順 8、 3の画像 1 Motorola Razr V3c Screen (CDMA) Replacement: 手順 8、 3の画像 2 Motorola Razr V3c Screen (CDMA) Replacement: 手順 8、 3の画像 3
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
  9. Motorola Razr V3c Screen (CDMA) Replacement, Screen (CDMA): 手順 9、 1の画像 1
    • Disconnect the metallic ribbon cover.
  10. Motorola Razr V3c Screen (CDMA) Replacement: 手順 10、 2の画像 1 Motorola Razr V3c Screen (CDMA) Replacement: 手順 10、 2の画像 2
    • Remove and replace the screen.
ゴール
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Joshua Ruehlig
メンバー登録日: 01/14/10
506 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G4
3 メンバー
8のガイドは作成済み
コメント 1 件
Is it a T5 or a T4 for removing the screws?
Francis Reyes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 9,404
