メインコンテンツにスキップ
Motorola Razr V3c Lower Casing (CDMA) Replacement
必要な工具と部品
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): 手順 1、 3の画像 1 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): 手順 1、 3の画像 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): 手順 1、 3の画像 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 2、 2の画像 1 Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 2、 2の画像 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): 手順 3、 1の画像 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 5、 1の画像 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 6、 2の画像 1 Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 6、 2の画像 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 7、 2の画像 1 Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 7、 2の画像 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 8、 1の画像 1
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): 手順 9、 2の画像 1 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): 手順 9、 2の画像 2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): 手順 10、 1の画像 1
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: 手順 11、 1の画像 1
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
krisko
メンバー登録日: 01/14/10
104 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 6,218
