はじめに
The purpose of this repair guide is to show how to replace the lower outer casing.
パーツ
パーツは必要ありません。
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Unscrew the two screws in the back using the T6.
Use the spudger to pop the bottom and the sides of the back casing
Peel off the connector between the motherboard and the body of the phone
Pull out the two black rubber covers using tweezers
Pull out the white plastic cover by unclipping the two plastic pieces shown
Pull out the speaker
Pull out the motherboard.
You may also now replace the bottom lower casing
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
Pull off and replace the lower front casing
ある他の人がこのガイドを完成しました。
With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
walltoall - 返信
