メインコンテンツにスキップ
Motorola Razr V3 Motherboard Replacement
必要な工具と部品
  1. Motorola Razr V3 Motherboard Replacement, Battery: 手順 1、 2の画像 1 Motorola Razr V3 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Motherboard Replacement: 手順 2、 2の画像 1 Motorola Razr V3 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Motherboard Replacement, SIM Card: 手順 3、 1の画像 1
    • Remove the SIM card by pulling it toward the top of the phone with your thumb.
  4. Motorola Razr V3 Motherboard Replacement, Antenna: 手順 4、 1の画像 1
    • Unscrew the two 5mm T6 Torx screws form the phone.
  5. Motorola Razr V3 Motherboard Replacement: 手順 5、 1の画像 1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  6. Motorola Razr V3 Motherboard Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  7. Motorola Razr V3 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
  8. Motorola Razr V3 Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Use a spudger or blue opening tool to pry the motherboard away from the back casing.
    • The speaker and the motherboard are magnetic and will most likely come up with each other.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Matthew Cristler
メンバー登録日: 04/21/13
184 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G46
4 メンバー
8のガイドは作成済み
コメント 1 件
Step 7 seems wrong to me. I almost broke my phone following the instructions.
To remove the antenna, you remove the two black plastic/rubber stoppers by prying them out. Then you have access to the two tabs underneath the stoppers. There are also tabs on the clear housing than hook into the bottom of the tabs on the main casing used to hold the two parts of the case together. I started on one side and gently went across, prying the tabs up.
Justin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 34
今までの合計 5,044
