はじめに
This guide will show you how to install the Motorola Razr V3 camera. You may need to install a new camera if the camera doesn't show any picture or otherwise does not work.
必要な工具と部品
ビデオの概要
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
この手順で使用する道具:Tweezers$4.99
Use tweezers to pry off the four rubber screw covers from the inside face.
Use tweezers to flip up the ZIF tab on the camera ribbon cable socket.
Gently pull the camera ribbon cable out of the ZIF socket.
2 の人々がこのガイドを完成させました。
