Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
Caution: Remove carefully, if broken, the phone will not be able to make calls.
Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
Caution: Remove carefully, if broken, the phone will not function properly.
Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
Caution: Do this gently Unclipping too fast may cause damage to your phone.
Use a spudger to pry the plastic screen casing partially up from the LCD unit.
Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
Caution: If the LCD will not function properly if this ribbon cable is broken.
Pull the plastic screen casing directly away from the LCD unit.
Turn the plastic screen casing over.
Carefully use a spudger to push the on the two clips holding the navigational pad in place.
You may have to pry the pad away from the plastic screen casing with the spudger.
Use a plastic opening tool to pry the screen up, being mindful of the glue holding the screen to its casing.
Pull the screen directly away from the casing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
