メインコンテンツにスキップ
Motorola RIZR Z3 Screen Replacement
必要な工具と部品
  1. Motorola RIZR Z3 Screen Replacement, Battery: 手順 1、 2の画像 1 Motorola RIZR Z3 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Screen Replacement: 手順 2、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 2、 2の画像 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Screen Replacement, Motherboard: 手順 3、 1の画像 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Screen Replacement: 手順 4、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Screen Replacement: 手順 5、 1の画像 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Screen Replacement: 手順 6、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Screen Replacement: 手順 7、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 7、 2の画像 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Screen Replacement: 手順 8、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 Screen Replacement, Screen: 手順 9、 1の画像 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 Screen Replacement: 手順 10、 1の画像 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 Screen Replacement: 手順 11、 1の画像 1
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 Screen Replacement: 手順 12、 3の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 12、 3の画像 2 Motorola RIZR Z3 Screen Replacement: 手順 12、 3の画像 3
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: If the LCD will not function properly if this ribbon cable is broken.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 Screen Replacement: 手順 13、 1の画像 1
    • Turn the plastic screen casing over.
    • Carefully use a spudger to push the on the two clips holding the navigational pad in place.
    • You may have to pry the pad away from the plastic screen casing with the spudger.
  14. Motorola RIZR Z3 Screen Replacement: 手順 14、 2の画像 1 Motorola RIZR Z3 Screen Replacement: 手順 14、 2の画像 2
    • Use a plastic opening tool to pry the screen up, being mindful of the glue holding the screen to its casing.
    • Pull the screen directly away from the casing.
終わりに
作成者
5人の作成者と共同で作成されました。
Brooke Shuford
メンバー登録日: 10/10/11
65 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011人のメンバー
CPSU-AMIDO-F11S5G34
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,479
