メインコンテンツにスキップ
Motorola RIZR Z3 LCD Replacement
必要な工具と部品
  1. Motorola RIZR Z3 LCD Replacement, Battery: 手順 1、 2の画像 1 Motorola RIZR Z3 LCD Replacement, Battery: 手順 1、 2の画像 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 LCD Replacement: 手順 2、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 2、 2の画像 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 LCD Replacement, Motherboard: 手順 3、 1の画像 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 LCD Replacement: 手順 4、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 LCD Replacement: 手順 5、 1の画像 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 LCD Replacement: 手順 6、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 LCD Replacement: 手順 7、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 7、 2の画像 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 LCD Replacement: 手順 8、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 LCD Replacement, LCD: 手順 9、 1の画像 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 LCD Replacement: 手順 10、 1の画像 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 LCD Replacement: 手順 11、 1の画像 1
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 LCD Replacement: 手順 12、 3の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 12、 3の画像 2 Motorola RIZR Z3 LCD Replacement: 手順 12、 3の画像 3
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 LCD Replacement: 手順 13、 2の画像 1 Motorola RIZR Z3 LCD Replacement: 手順 13、 2の画像 2
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
終わりに
作成者
5人の作成者と共同で作成されました。
Brooke Shuford
メンバー登録日: 10/10/11
65 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011人のメンバー
CPSU-AMIDO-F11S5G34
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,076
