はじめに
The motherboard needs to be removed in order to access the headphone jack. This guide involves the removal of various screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
必要な工具と部品
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Use the Torx T5 screwdriver to remove two 4.0 mm screws on the cover of the headphone jack in the upper right corner.
ある他の人がこのガイドを完成しました。
