メインコンテンツにスキップ
Motorola RAZR Maxx HD Headphone Jack Replacement
必要な工具と部品
  1. Motorola RAZR Maxx HD Headphone Jack Replacement, Screen Removal: 手順 1、 2の画像 1 Motorola RAZR Maxx HD Headphone Jack Replacement, Screen Removal: 手順 1、 2の画像 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 2、 2の画像 1 Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 2、 2の画像 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 3、 2の画像 1 Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 3、 2の画像 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 4、 2の画像 1 Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 4、 2の画像 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Headphone Jack Replacement, Headphone Jack: 手順 5、 1の画像 1
    • Use the Torx T5 screwdriver to remove two 4.0 mm screws on the cover of the headphone jack in the upper right corner.
  6. Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 6、 2の画像 1 Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 6、 2の画像 2
    • Using the spudger tool, release the ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  7. Motorola RAZR Maxx HD Headphone Jack Replacement: 手順 7、 1の画像 1
    • Using the pointy end of the spudger, gently pry the headphone jack from the motherboard and remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
David Twyman
メンバー登録日: 02/03/15
135 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G40
5 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 325
