メインコンテンツにスキップ
Motorola RAZR Maxx HD Battery Replacement
必要な工具と部品
  1. Motorola RAZR Maxx HD Battery Replacement, Screen Removal: 手順 1、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement, Screen Removal: 手順 1、 2の画像 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Battery Replacement: 手順 2、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 2、 2の画像 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Battery Replacement: 手順 3、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 3、 2の画像 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Battery Replacement: 手順 4、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 4、 2の画像 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 手順 5、 3の画像 1 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 手順 5、 3の画像 2 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: 手順 5、 3の画像 3
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
  6. Motorola RAZR Maxx HD Battery Replacement: 手順 6、 1の画像 1
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
  7. Motorola RAZR Maxx HD Battery Replacement: 手順 7、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 7、 2の画像 2
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
  8. Motorola RAZR Maxx HD Battery Replacement: 手順 8、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 8、 2の画像 2
    • Using tweezers, remove the back facing camera cover.
  9. Motorola RAZR Maxx HD Battery Replacement: 手順 9、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 9、 2の画像 2
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  10. Motorola RAZR Maxx HD Battery Replacement: 手順 10、 1の画像 1
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
  11. Motorola RAZR Maxx HD Battery Replacement: 手順 11、 3の画像 1 Motorola RAZR Maxx HD Battery Replacement: 手順 11、 3の画像 2 Motorola RAZR Maxx HD Battery Replacement: 手順 11、 3の画像 3
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
  12. Motorola RAZR Maxx HD Battery Replacement, Battery: 手順 12、 2の画像 1 Motorola RAZR Maxx HD Battery Replacement, Battery: 手順 12、 2の画像 2
    • Wedge the spudger tool under the battery to remove it from the back case.
終わりに
12 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Anna Sullivan
メンバー登録日: 02/01/15
880 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G40
5 メンバー
18のガイドは作成済み
コメント 1 件
When putting it all back together, is it recommended to replace the pieces of tape to protect/insulate the connectors, or is that not necessary?
FreeMan - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 20
今までの合計 5,469
