メインコンテンツにスキップ
Motorola Q700 Sidekick Speaker and Camera Replacement
必要な工具と部品
  1. Motorola Q700 Sidekick Speaker and Camera Replacement, Phone: 手順 1、 1の画像 1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 2、 1の画像 1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 3、 1の画像 1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 4、 1の画像 1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 5、 1の画像 1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 6、 1の画像 1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 7、 1の画像 1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Speaker and Camera Replacement, Speaker and Camera: 手順 8、 1の画像 1
    • complete dissassembly as instructed by guide
  9. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 9、 1の画像 1
    • Remove camera piece from casing
  10. Motorola Q700 Sidekick Speaker and Camera Replacement: 手順 10、 1の画像 1
    • replace with new camera piece into casing and reassemble by reversing dissemble procedure
終わりに
作成者
3人の作成者と共同で作成されました。
Rich
メンバー登録日: 04/08/13
125 ポイント
6のガイドは作成済み
チーム
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 230
