メインコンテンツにスキップ
Motorola Q Global Display screen Replacement
必要な工具と部品
  1. Motorola Q Global Display screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Display screen Replacement: 手順 2、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 2、 2の画像 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Display screen Replacement, Display screen: 手順 3、 1の画像 1
    • Press inwardly on the upper casing to release.
  4. Motorola Q Global Display screen Replacement: 手順 4、 1の画像 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Display screen Replacement: 手順 5、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 5、 2の画像 2
    • Remove the 6 screws using the T5 torx screwdriver.
  6. Motorola Q Global Display screen Replacement: 手順 6、 1の画像 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Display screen Replacement: 手順 7、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 7、 2の画像 2
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Display screen Replacement: 手順 8、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 8、 2の画像 2
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Display screen Replacement: 手順 9、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 9、 2の画像 2
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  10. Motorola Q Global Display screen Replacement: 手順 10、 2の画像 1 Motorola Q Global Display screen Replacement: 手順 10、 2の画像 2
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  11. Motorola Q Global Display screen Replacement: 手順 11、 1の画像 1
    • Insert the new LCD screen into the circuit.
終わりに
作成者
6人の作成者と共同で作成されました。
Will Dickman
メンバー登録日: 09/27/12
28 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G31
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 827
