メインコンテンツにスキップ
はじめに
This guide will focus on disassembling the necessary components for the phone in order to get to the camera hardware and remove it from the motherboard.
パーツ
パーツは指定されていません。
  1. Turn the phone face down.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown. When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Press inward on the upper casing.
    • Press inward on the upper casing.
  4. Slide the upper case to the right and lift up.
    • Slide the upper case to the right and lift up.
    • Lift the camera sticker so that it doesn't get damaged.
  5. Remove the six labeled screws with a T5 Torx Screwdriver. Remove the six labeled screws with a T5 Torx Screwdriver.
    • Remove the six labeled screws with a T5 Torx Screwdriver.
  6. Once the screws are removed, use the plastic opening tool to remove the black casing.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Remove both screws on the mounted surface with a T5 screwdriver. Remove both screws on the mounted surface with a T5 screwdriver.
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool. Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Use the plastic opening tool to lift the camera from the phone.
    • Use the plastic opening tool to lift the camera from the phone.
  10. The new camera can now be attached to the motherboard.
    • The new camera can now be attached to the motherboard.
まとめ
Jorge Vanegas Moran
メンバー登録日: 2012年10月03日
8 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G31
5 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 563
