メインコンテンツにスキップ
Motorola Photon 4G MB855 Motherboard Replacement
必要な工具と部品
  1. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: 手順 1、 2の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: 手順 1、 2の画像 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: 手順 2、 2の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: 手順 2、 2の画像 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 手順 3、 3の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 手順 3、 3の画像 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: 手順 3、 3の画像 3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 手順 4、 3の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 手順 4、 3の画像 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: 手順 4、 3の画像 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 手順 5、 3の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 手順 5、 3の画像 2 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: 手順 5、 3の画像 3
    • Locate the Display Data Cables
    • Use hands or plastic opening tool to carefully pry off the connectors.
  6. Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 手順 6、 3の画像 1 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 手順 6、 3の画像 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: 手順 6、 3の画像 3
    • Be careful when removing the motherboard. The earpiece is connected with small wires and adhesive. Use a thin tool to pry it off before removing the motherboard.
    • Use a plastic opening tool to gently pry off each section of the Motherboard.
    • Slowly and carefully remove the motherboard from the front panel assembly.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Eddie Krause
メンバー登録日: 10/07/14
260 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-6, Leahy Fall 2014 USF Tampa, Team 8-6, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S8G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,362
