必要な工具と部品
The red line indicates the opening, follow it all the way around the phone.
Peel the small yellow tab away with a small flathead screwdriver.
Slide the metal shield down to unlock and remove it.
Use a small flathead to loosen the cover.
Around the red markers are little clips that keep it in place.
Inside the red marker, disconnect the battery cable and carefully pull the battery out.
Use a non-metal prying tool to pull the corners up and apply heat to soften the glue in the process.
Be careful and make sure that the battery doesn't bend too far or breaks.
8 の人々がこのガイドを完成させました。
