1. Remove the back cover by sliding the clip and lifting up the bottom of the cover.
    • Remove the back cover by sliding the clip and lifting up the bottom of the cover.
  2. Remove screws 1 through 4. Remove screws 1 through 4.
    • Remove screws 1 through 4.
  3. Once all four screws are removed, you should be able to pop off the back half of the phone.
    • Once all four screws are removed, you should be able to pop off the back half of the phone.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Flip the logic board up to reveal the back of the keypad.
    • Flip the logic board up to reveal the back of the keypad.
  6. Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
    • Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
  7. Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
    • Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
    • Secure the rest of the key pad.
  8. Put the logic board back into place and reattach cable number 1.
    • Put the logic board back into place and reattach cable number 1.
  9. Snap the front and back of the phone back together and reinsert screws 1 through 4.
    • Snap the front and back of the phone back together and reinsert screws 1 through 4.
まとめ
Danielle Matthews
メンバー登録日: 2014年10月17日
13 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G7
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 66
