はじめに
Use this guide to remove or replace the screen on your Motorola Moto Z3 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you're replacing the display anyway, then you don't have to worry—but if you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
必要な工具と部品
Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
Apply an iOpener to the bottom edge of the display assembly for about a minute to loosen the adhesive beneath the fingerprint sensor.
Compare your new replacement part to the original part—you may need to transfer any remaining components or remove adhesive backings from the new part before installing.
27 の人々がこのガイドを完成させました。
9 件のコメント
This is a guide for disassembly only. There are a few further steps required to replace front,,,
