メインコンテンツにスキップ
はじめに
The modularity and easy to remove battery found in the Lenovo Moto Z earns it a 7 out of 10 on the repairability scale.
  1. Motorola Moto Z Repairability Assessment, Reference front/back: 手順 1、 3の画像 1 Motorola Moto Z Repairability Assessment, Reference front/back: 手順 1、 3の画像 2 Motorola Moto Z Repairability Assessment, Reference front/back: 手順 1、 3の画像 3
    • External expansion is possible with magnetically attached "Moto Mods." Easily swapped external battery packs may increase life of device.
  2. Motorola Moto Z Repairability Assessment: 手順 2、 3の画像 1 Motorola Moto Z Repairability Assessment: 手順 2、 3の画像 2 Motorola Moto Z Repairability Assessment: 手順 2、 3の画像 3
    • Sticky adhesive holds the display in place. Heat is required to soften the adhesive enough to pry up the display.
    • This adhesive is similar to adhesive found in waterproof devices like the iPhone 6s/7. This device is splashproof, not waterproof.
    • The display cable is long enough to allow you to fold the display over completely, so you don't have to support it while disconnecting.
    • However, it is very wide and hinders access to the battery connector—it's considerably easier to disconnect the battery after the screen is removed, which is not best practice.
  3. Motorola Moto Z Repairability Assessment: 手順 3、 2の画像 1 Motorola Moto Z Repairability Assessment: 手順 3、 2の画像 2
    • The fingerprint sensor button and ambient light sensor are held onto the back of the display assembly with strong adhesive.
    • Heat was not needed, and both components can be easily reinstalled.
    • To test the most common repair, we remove the battery before proceeding.
    • Battery has a plastic tab to aid in removal. The angle helps avoid ripping the tab off before it's free from the adhesive in the lower right corner.
  4. Motorola Moto Z Repairability Assessment: 手順 4、 1の画像 1
    • Vibrator and rear-facing camera are lightly adhered in place and can be removed now, (or before the battery is removed).
    • Earpiece speaker assembly and lower bracket are held in place with Torx T3 screws and serve to hold down the top and bottom halves of the motherboard.
  5. Motorola Moto Z Repairability Assessment: 手順 5、 2の画像 1 Motorola Moto Z Repairability Assessment: 手順 5、 2の画像 2
    • Removing the adhered motherboard
    • Motherboard as a single component is an expensive repair, especially with the commonly failing charging port soldered on.
    • With the motherboard removed, the next layer of components can come out, including: front-facing camera, camera cover/LED flash assembly, heat pipe, button covers and switch ribbon cable.
  6. Motorola Moto Z Repairability Assessment: 手順 6、 2の画像 1 Motorola Moto Z Repairability Assessment: 手順 6、 2の画像 2
    • The Lenovo Moto Z earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • Pull-tab on battery, easy to access once you have the device open.
    • Modular assembly allows independent replacement of many components
    • Display is adhered in place with no external fasteners, but the adhesive is weak enough to easily separate after heating.
    • Charging port soldered to the motherboard means a common repair will be very expensive.
    • Manufacturer does not provide user-accessible repair documentation.
ゴール
29 の人々がこのガイドを完成させました。
Andrew Optimus Goldheart
メンバー登録日: 2009年10月17日
487,764 ポイント
410のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
145 メンバー
15,517のガイドは作成済み
10 件のコメント
Is it possible to replace only the botoom part?
Ben Morningstar - 返信
hi, do you have a wallpaper like the one on the iphone x so i can see the internals? thanks
leandrofernandez91 - 返信
Is there a way to repair the WIFI Chip?
Tobias S - 返信
i also have the same que… how to repair WIFI ???
Syed Saif -
Disculpen las guías no vienen en Español,? Gracias
jesús eduardo thome - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 78
今までの合計 18,925
