メインコンテンツにスキップ
Motorola Moto X 2nd Generation Back Cover Replacement
必要な工具と部品
ビデオの概要
  1. Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 手順 1、 3の画像 1 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 手順 1、 3の画像 2 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Back Cover Replacement: 手順 2、 3の画像 1 Motorola Moto X 2nd Generation Back Cover Replacement: 手順 2、 3の画像 2 Motorola Moto X 2nd Generation Back Cover Replacement: 手順 2、 3の画像 3
    • Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Back Cover Replacement: 手順 3、 2の画像 1 Motorola Moto X 2nd Generation Back Cover Replacement: 手順 3、 2の画像 2
    • Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
    • At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
終わりに
19 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sophia
メンバー登録日: 03/25/14
43,810 ポイント
62のガイドは作成済み
3 件のコメント
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
Hassan Almarzooq - 返信
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
[deleted] - 返信
What type of adhesive do you use to reseal the back cover?
sfcvickers - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 26,094
