はじめに
すぐに消耗してしまうバッテリー寿命に辟易していますか?このガイドを使って、Motorola Moto Xのバッテリーを交換しましょう。バッテリーが膨張している場合は、適切な方法で処理してください。
必要な工具と部品
ビデオの概要
SIMカードスロット近くのフロントカバーとリアカバー間のシームに、プラスチック製の開口ツールを挿入します。
プラスチックの開口ツールをシームに沿って上部コーナーに向けてスライドさせます。
カバーを固定している残りのクリップを全て外し、四方のシームに沿って開口ツールをスライドします。
Be *very* careful not to push the opening tool too deep when you go around the buttons! I accidentally broke the volume rocker ribbon by doing so, and didn't even realize it until I had completely removed the cover.
When i removed the volume rocker i cant get it back in correctly seems to be in right but the volume up is not clicking and only works if i push it really hard any ideas?
iOpenerを温めて、デバイス上に約90秒間載せてください。バックカバーに付けられた接着剤を緩めます。
There is NO GLUE holding on the back of a Moto X with a wood back! That little fact just made the extra $50 I spent on the phone totally worthwhile.
Lucky for you, I have the bamboo, and plenty of adhesive.
Kelly F -
SIMスロット側から、デバイスのリアカバーを慎重に剥がします。
Step 15 seemed to be the hardest part for me. (step 25, the battery was also difficult). I am now not a fan of sticky stuff, "Mild adhesive" is definitely an understatement, IMHO, just saying I don't like sticky stuff, maybe I didn't do it right. The iOpener seemed to help a little, but not much.
CAUTION
BE CAREFUL with the NFC antenna, it says "X8 Mobile Computing System" on it. The adhesive seemed stick to the the blue stuff on the back cover more and loosen up on the bottom of the antenna, the part that sticks to the battery. So in the process of peeling the back cover the antenna started to come up and was torn at the connector strip before I realized what was happening, step 19 has a good picture of the connector strip that I'm talking about. I like using NFC once in awhile, so now my next FIX will be the antenna.
Overall instructions were GREAT, I now have a camera again. Thank you.
So you are saying that there is no problem if I don't connect the NFC antenna? I'm asking this because I bought a replacement battery that don't include the NFC antenna. I would really appreciate your help with this :)
The adhesive was crazy hard on mine as well and I ended up with two small cracks on the edges of my back cover. The blue rubber piece actually separated from the back and removed it from the battery after it was open. The battery itself was also very difficult to remove (pull tab did nothing) and bent/pried the old battery out. I see no reason for all that adhesive! Other than getting the dang thing open the rest was easy. Great guide!
The adhesive holding the back very strong! In the process of removing the back, I cracked the edges of the back cover and ripped part of the NFC connector. Luckily the friend I was doing the repair for did not even know what NFC was, so she was ok with this. Take your time removing the back cover! Also, the adhesive holding the battery in place was not what I would call mild. The black tab was next to useless in removing the battery
カメラのフラッシュケーブルコネクタが露出するように、リアカバーをゆっくりと開きますが、コネクタに圧力がかからないようにご注意ください。
As I had seen in another video, my Moto X with a custom back did not have the blue sticky pad. But the back was still well-adhered in the top corners and with a strip of adhesive along the bottom. In the photo in this step you can see the only adhesive I had to deal with, which was on either side of the lens (two dark areas on the phone back) and along the bottom of the phone (dark area at the bottom of the phone back).
デバイスに下側アンテナアセンブリを固定している、3 mm T3トルクスネジを4本外します。
It turns out to be the hardest step at the moment. I ordered iOpener set, and it is almost useless. It doesn't have t3, only t5, the actual iOpener is useless. I would happily order t3 on ifixit.com, but there is no t3 in Germany, so I ordered on amazon, and it turned out to be a complete $@$*, I was not able to take a single screw out. The guide is really good, I never thought I would have an issue with a screwdriver ....
These screws were definitely incompatible with my T3 bit - it was too small. T4 worked fine. Not sure if I should attribute this to an error in the guide or inconsistency in the size of my bit set; in any case it might be handy to have a T4 handy if you're not buying the iFixit screwdriver.
Drilled out the heads. A bit scary, yes. I agree with another commenter here that my T3 isn't the best fit in these screws. My T3 was a pretty cheap eBay acquisition, so who knows where the blame should go. I wouldn't do this repair again. Phones should be easier to break open than this one. Too much adhesive (and as I mentioned above, mine didn't even have the blue adhesive pad) and T3 heads are super small and asking to be stripped and the two screws I did get out were way too tight. Oh, and also the potential butchering of the cover when prying loose the clips. Mine bent a bit around the headphone jack, but it smoothed back down and is not noticeable. Phone powered up and is charging now. Let's hope it was worth it.
On my phone, the screws were DEFINITELY T4. My advise? Try T4 first. If it's too big, nothing lost.
I nearly stripped the head on one of mine with my T3 bit because it was too small to get traction.
I use chinese version of T3 screwdriver shipped with screen and T3/T4/T5 version of MATRIX tool set - both didnt fit for Moto X 1st gen screws. Only Bernstain T3 6-658 screwdriver fits ideally! Spent 2 days to find this tool. Be aware.
I was able to do this step by grinding down a cheap T3 that I had laying around from another repair. Like others, I found that these screws seem larger than a T3 - stripped one and had to drill it out. Since the T3 screwdriver I had was tapered, I ground it down until the end was large enough to grip the remaining screws. Success!
スパッジャーの平面側先端を使って、デバイスから下側アンテナアセンブリをこじ開けて、解放します。
アンテナアセンブリを取り出します。
See that little circular rubber near the bottom right screw? This funnels the background noise to one of the noise canceling microphones. It will be destroyed when you take it off. Freaked me out when I first opened up mine.
This foam "funnel" required re-forming of the center hole (also check hole in back cover foam gasket). If this sound channel gets blocked, the noise canceling will not function properly. Before re-installing the lower antenna assembly, check the oblong 2-hole gasket on the back side of the antenna assembly which covers a sound channel to the offset microphone input hole. If deformed, gently reshape it with tweezers to assure both holes are not plugged.
ktmorimoto - 返信
my antenna going away after change battery
found networks but not registered , factory reset ,
please help me
スパッジャーの先端を、コネクタ付近のバッテリーケーブルの下に差し込み、ソケットからまっすぐ持ち上げます。
スパッジャーの平面側先端を使って、NFCアンテナケーブルコネクタの接続を外します。
交換しなくても、またはコイルが損傷していても、デバイスはコイルなしでも機能しますが、NFC機能は失われます。
温めたiOpenerをNFCアンテナに約90秒間当てます。
交換用のパーツとオリジナルのパーツを見比べてください。残りのコンポーネントを移植する必要があるか、パーツを装着する前に接着剤の裏張りを取る必要があります。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
この修理ガイドを完成したら、新しく装着したバッテリーのキャリブレーションを行なってください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?トラブルシュートのヘルプには、Motorola Moto X アンサーコミュニティを参照してください。
114 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
35 件のコメント
Cool but where to buy the spare battery?
Thanks
Nice, detailed guide. In fact so detailed, I do not trust myself making this repair. Does anyone offer this as a service (for a fee)?
This doesn't address the antenna stuck on (but separate) from the battery. It's easy enough to see in the pictures, but it doesn't come off easily in one piece. I think mine still works, but definitely needs addressing.
Yes - getting the antenna off is a bear. I - well, my cell-phone guy - didn't bother because I don't use NFC for anything, so I hope that was okay!
Thanks for the guide...I'm wondering how to re-attach the back cover? Did you warm up the adhesive with the iOpener before snapping it back on?
greentree8 - 返信
Hi i was wondering if anyone could answer me am i able to use the X1058 batter on a moto x thats X1060
I was unable to remove the back cover without causing small cracks.
The iOpener sort of worked but I ended up using a mini hair dryer I had, directing the airflow inside the phone to open it.
If you are not very near sighted, don't try this without a magnifier stand.
A suction cup came in the iFixit kit. The proper use of it should be shown in the instructions. There were a few other parts that came in the kit but I did not use, but later realized they might be helpful. The instructions should show their use.
iFixit might consider selling for say $5 a glossy paper copy of the instructions.
The battery in my phone has Revision B printed on it. The battery I bought of eBay had Revision A on it. iFixit should let readers know what the difference is if any. The battery I got had an antenna and some other parts on it. In general iFixit should give better battery selection and purchase advice.
Performed the battery replacement tonight. Took a risk removing the back cover without applying heat ... the adhesive came loose with a little patience (although I did end up with a small crack to the side of the back cover ... shouldn't be a problem since I use the phone with a case anyway).
Thank you iFixit for this guide including the great photos!
My battery is starting to discharge faster lately, which is over two years old. But looking at this guide and trying to change a broken screen on a moto x once before this is not for the unskilled, butter fingers, etc. I also found out the glass screen is glued to the display so essentially its non serviceable . Then there is the annoying problem of the phone dropping the wifi (no other device in the house has this problem). I tried several corrections found on the internet, nothing has worked. BUY ANOTHER PHONE.
I absolutely could not get the four T3 screws to come out. They stripped almost immediately so i had to drill the heads of the screws. Thankfully the phone still worked. Put a little dab of super glue in place of the screws.
I just made the change, but the battery improvement is little. Is it necessary to make a factory reset?
Ok, I'm a female, non-electrical type. I followed this guide from start to finish, step by step. It was very well photographed! I was able to complete this repair, plugged in and voila! Phone works!!! Thank you for this amazing guide. It was the first time I attempted anything like this and just going slow and steady was great! The most important thing are your tools. Thank goodness for Fry's as the cheapo Amazon kit I got didn't quite cut it. That T3 torx screwdriver saved my life...Just goes to show, a little patience, a little know-how and you are good to go! Thanks ifixit.com!
Awesome job, Wendi! You're a champ! Keep up the good work! =)
Thank you - this is a very helpful guide! The text is clear and many of the steps have a series of photos that clearly communicate what to attend to, how to start, and what it looks like when you are doing the process correctly. I haven't done this kind of repair before so it took a little while to gather the information, materials, and courage, but once I started it only took 30 minutes and everything works great.
this is it - 返信
Wonderful guide. I was able to replace the battery in 20 minutes... Having the detailed guide gives you the knowledge needed to do the job quickly and easily.
I bought my battery form a 3rd party vendor on Amazon for about $20. It appears to be a factory battery (has the same labeling as the original battery).
Is it ok to place the sim card on the magnetic mat? I noticed that in the video Gwendolyn (sp?) set the sim card right on the magnetic mat right after she took it out. I'm afraid to do that with mine. Does anyone know for sure if that would mess the sim card up?
You should be safe! The magnetic project mat is strong enough to hold tiny screws, but not strong enough to wipe data from a SIM card. But you can always place the card elsewhere, just don't lose it!
I had no idea I was ripping the NFC connector was being destroyed as I pried the cover off. Hard to hold the phone for this repair. Suction cup could be very helpful.
David Karr - 返信
Excellent guide ! Thank you!!! This old back cover was a tad brittle, but nothing that can be fixed.
Thanks for the pain taking time you took to carefully explain this gruesome process. Please keep up the good work. What it means is that once the battery is dead, it is time to replace the entire phone with a new one.
These instructions are very clear. However despite being very careful, I quickly got two small cracks in the back cover while attempting to remove it using the tool provided. The back cover seemed very brittle. I discontinued the removal and ordered two replacement backs to ensure I will have an intact one to install over the new battery.
Thanks for the guide. To loosen the adhesive on the back cover, I used a damp cloth heated in the microwave, and then placed in a plastic zip lock bag as my DIY IOpener. Ended up having two of the antenna assembly torx screws heads strip on me. Had to use my Dremel to notch a groove in one. Was then able to get it out with a small flat head screw driver. The other screw I ended up grinding the head off. Put everything back together (with only 3 torx screws holding the antenna assembly), and the phone is working great.
Excellent instructions and video. Makes it look simple. But I have been dreading this for months. 4 year old Moto, treated very gently. Back is cracked at least a dozen places all around edge and simply would not come off without prying and chiselling (?) off the glue. Perhaps because I live in Phoenix, the “heat sensitive glue” almost would NOT release the battery. Also, new battery didn’t have any, so is in there “loose” with traces of the old glue. It snapped right back together, and all phone functions worked fine. Will buy a new back though, all that cracking is unsightly.
I’m happy after refurbishing my precious Moto X. If you take this on, make sure to have a Torx T3 driver— don’t attempt to use a T4. Also you will definitely crack the back cover when removing it (especially given the plastic is 5 years old now). I strongly recommend buying a replacement back cover in advance. The new OEM cover I found cost less that 10 USD and had integrated adhesive stickers and flash assembly.
The key to this is patience. It’s neither difficult nor complicated, just frustrating. The back cover disassembly was very frustrating. I applied the iOpener for 90 seconds, at least 4-5 times. If you don’t feel the cover coming off slowly, then reapply the heat. Don’t risk breaking the cover (though cracks are inevitable). Also, be very careful when removing the screws. They’re so %#*@ tiny and I lost one. Other than that, the replacement should be pretty smooth. I got my new battery in, including the NFC antennae, and everything seems to be working fine, despite the one missing screw. Just be patient.
I finally had to face the fact that my beloved 5+ year-old Moto X had to have a new battery. Glad I stumbled over this DIY video first, before I paid a geek to do it for me
a few things i noticed:
1) it’s almost impossible to do this without cracking the back cover. mine was already cracked (partially from it just being old, partially from the battery having expanded and cracking the side where the buttons are), so i had already ordered the replacement…the battery just happened to come in before the back cover did.
2) the heat never got the adhesive loose enough to the point where the back cover would come off easily. i basically had to just continually peel very slowly.
3) if some of the cables come off while you’e removing the cover, don’t panic. my nfc and flash cables both pulled loose before i got to that point (the nfc cable came out while the antenna was still in place), and both still work just fine.
4) nfc antenna may end up still attached to the back cover. when i took the case off, i ended up pulling the nfc antenna from the battery rather than the case from the nfc antenna. still works fine, just may have your steps out of order with the video.
Sim not work
Radhey Kashyap - 返信
