メインコンテンツにスキップ
Motorola Moto Q Keyboard Replacement
必要な工具と部品
  1. Motorola Moto Q Keyboard Replacement, Back Casing: 手順 1、 1の画像 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Keyboard Replacement: 手順 2、 1の画像 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Keyboard Replacement: 手順 3、 2の画像 1 Motorola Moto Q Keyboard Replacement: 手順 3、 2の画像 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Keyboard Replacement: 手順 4、 2の画像 1 Motorola Moto Q Keyboard Replacement: 手順 4、 2の画像 2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Keyboard Replacement, Camera: 手順 5、 2の画像 1 Motorola Moto Q Keyboard Replacement, Camera: 手順 5、 2の画像 2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Keyboard Replacement: 手順 6、 2の画像 1 Motorola Moto Q Keyboard Replacement: 手順 6、 2の画像 2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Keyboard Replacement: 手順 7、 2の画像 1 Motorola Moto Q Keyboard Replacement: 手順 7、 2の画像 2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Keyboard Replacement: 手順 8、 2の画像 1 Motorola Moto Q Keyboard Replacement: 手順 8、 2の画像 2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q Keyboard Replacement, Keyboard: 手順 9、 3の画像 1 Motorola Moto Q Keyboard Replacement, Keyboard: 手順 9、 3の画像 2 Motorola Moto Q Keyboard Replacement, Keyboard: 手順 9、 3の画像 3
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
終わりに
作成者
6人の作成者と共同で作成されました。
Luis Herrera
メンバー登録日: 01/21/10
52 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S16G33
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 4,109
