はじめに
This repair guide shows you how to remove the camera so it can be fixed or replaced.
必要な工具と部品
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
ある他の人がこのガイドを完成しました。
