はじめに
Motorola Moto G5 Plus のホームボタンが動かなくなることがあります。ホームボタンが反応しない場合は、このガイドを使って新しいボタンと交換してください。
必要な工具と部品
温めたiOpenerをデバイスの正面の左側端に約2分間載せます。熱くて触れない程度までの加減です。この作業により、ディスプレイに留められた接着剤を柔らかくできます。
Heat not only along the phone’s left edge, right?
I used two suction cups on the screen. Just above the finger print reader and the other near the top. Then used my heatgun set at 390 degrees. Low speed and had the wide, flat blade attachment so the heat spread to a narrow/wide area. Heated the left edge from corner to corner, then pulled up on the suction cups until I could work in a plastic triangle guitar-like-pic under the screen. Continued to heat and add another pick around the screen . Do not rush and take your time. Got the screen off and didn’t damage the adhesive too bad. Was able to reuse it. Once reassembled, I heated the screen around the edge and rubbed with a plastic tool to make sure the adhesive was working. So far so good with the adhesive. Good Luck!
strtrekbuf - 返信
2番目と3番目の画像を参照して、ディスプレイ周辺の接着剤の幅がどれぐらいあるか確認してください。
2mm ONLY on the SIDES of the display. The top can have adhesive as far as 10mm from the edge, and at the bottom as much as 12mm. And there’s no way to cut this adhesive with the tools at 45 degrees. Once the left side is open, carefully insert the tool a little further at a time on the top and bottom, whilst attempting to keep a little pull force on the suction cup. Hard to do, and almost inevitably the on-off button will be hit at some point unless you’re really careful. The adhesive pieces are quite tough, and I used a tiny scissors to cut some of the adhesive “ropes” when the case was far enough open. A highly detailed photo of the adhesive locations top and bottom (and on both parts) would help here. This is likely the most difficult step (well, don’t know for certain, ‘cause I haven’t got further yet…), and warrants better photos and explanation IMO.
続けて、デバイスの上部と右側の接着剤を切開します。
Pues se me fastidia la pantalla al hacer esto
This is a great guide except for one thing. My screen works fine but it is separating from the phone on both sides. I need to remove it just enough to clean up the old adhesive and reattach. The instructions on repeating the steps in reverse order to replace the screen doesn't help with getting the regluing right, what kind of glue or double sided tape to use, etc …
イヤホンの下に留められた黒いプラスネジを2本覆っている、黄色いステッカーを外します。
Attention must be paid not to lose the small rubber gasket around the proximity sensor - I found it best to collect it with all the screws of the midframe and reinstall it at the end during re-assembly.
ミッドフレームから次のネジを外します。
3.8 mm黒いネジー16本
2.4 mmシルバーネジー3本
Esa placa se levanta por el otro lado, por donde estan los botones de volumen por ahi se puede levantar de una mejor manera.
スパッジャー平坦側を、ミッドフレームとデバイス左端の間に差し込み、ミッドフレームを所定の位置に固定している2つのクリップを慎重に取り外します。
デバイスからディスプレイアセンブリを外します。
交換用のディスプレイにタッチ機能が付いていない場合、また付いているかどうかわからない場合は、データーをバックアップ保存して、ファクトリーリセットをしてください。
If your digitizer appears to be "dead", power down the phone (which you can't because the digitizer is dead) and disconnect the battery connector by prying the connector up out of its socket (with something NONE conductive like your spudge tool) for few seconds. (It does not "slide" out, but pries straight up.) This will FORCE a cold boot and initialize the digitizer WITHOUT a factory reset, preserving all setups and all your files. :-)
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
Any way to just clean the edges of the sensor without taking apart the entire phone?
Finger print scanner connector port get completely damaged. is this the reason my phone is not getting started
