はじめに
Replace the front camera on your Motorola Moto G5.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
Pry with your fingernail or twist the spudger to release the back cover from the phone.
Insert your fingernail or the flat end of the spudger into the notch below the battery.
Pry with your fingernail or spudger until you free the battery from its recess.
Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
Grab the connector with the tweezers and gently unplug the front camera from the motherboard.
4 の人々がこのガイドを完成させました。
