はじめに
これは、壊れたMotorola Moto G4 Plusのヘッドホンジャックを交換する手順毎のガイドです。
始める前に、Rescue and Smart Assistantアプリをダウンロードしてデバイスをバックアップし、問題がソフトウェアまたはハードウェアに関連しているかを診断してください。
必要な工具と部品
SIMカードをスライドして取り出します。
Tenho un Motorola g4 plus 64 G
El celular se volvía loco abriendo y cerrando aplicaciones
Ahora no reconoce la tarjeta SIM
Internet y Wasapp funciona
Alguien sabe donde lo reparan soy de Argentina Buenos Aires CABA
ミッドフレームに留められた3.1 mm T3 ネジを19本外します。
A pair of binocular magnifiers is helpful here. Also, a magnetic pickup will help pull the tiny screws out of their counterbores.
Well I'm stuck. 3 screw heads are stripped on mine, not lucky as they are two on USB port end and screw in-between two SIM slots. Phone bought new and this is 1st time screws have been touched, could see they were already stripped before getting screwdriver near them. Any tips on removing stripped screws?
Hi Mark,
I’m sorry to hear that! You can try some techniques from the stripped screw guide.
I found that a T4 driver was the correct size for the screws.
黒いプルタブをバッテリーから剥がして、ゆっくりと、力を入れてフレームからバッテリーを引っ張り、外します。
Does anybody know, what the black tape covering the metal cans an the battey is made of? It seems to have a heat insulating effect.
No, but the tape completely separated from itself when I removed it. Glue separated from the backing. I figure the glue in the frame is holding it well enough.
I found prying the battery out was the trickiest part of this job. Take your time and pry with the plastic tool, working from the end away from the wires, but try not to deform the battery in the process. It does finally come out.
Hi, I cannot remove the Battery, it has too strong glue. Any Ideas?
Regards
You can try to drip some high concentration isopropyl alcohol along the battery edge to help loosen the adhesive.
ピンセットを使って、フロントケースとマザーボードを繋いでいる、黒いシリコンピースを外します。
ピンセットを使って、フロントケースとマザーボードを繋いでいる赤と黒のケーブルを外します。
スパッジャーを使って、マザーボードとフロントケースを繋いでいる、2つのメタル製ピースを外します。
What is the purpose of that metal piece that is connected to the motherboard on the bottom left-hand side.
Its for the fingerprint scanner (only on the G4 Plus)
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
コメント 1 件
I accidentally broke the headphone jack ribbon cable socket off of the motherboard - its a very small 3 socket ZIF connector that wasn’t attached very good. Now I have no display - I’m wondering if the headphone jack has something to do with it? I would think breaking that connector would only affect the headphone jack.
