メインコンテンツにスキップ
Motorola Moto G4 Play Side Buttons Replacement
必要な工具と部品
  1. Motorola Moto G4 Play Side Buttons Replacement, Battery: 手順 1、 3の画像 1 Motorola Moto G4 Play Side Buttons Replacement, Battery: 手順 1、 3の画像 2 Motorola Moto G4 Play Side Buttons Replacement, Battery: 手順 1、 3の画像 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Side Buttons Replacement: 手順 2、 3の画像 1 Motorola Moto G4 Play Side Buttons Replacement: 手順 2、 3の画像 2 Motorola Moto G4 Play Side Buttons Replacement: 手順 2、 3の画像 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Side Buttons Replacement: 手順 3、 3の画像 1 Motorola Moto G4 Play Side Buttons Replacement: 手順 3、 3の画像 2 Motorola Moto G4 Play Side Buttons Replacement: 手順 3、 3の画像 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Side Buttons Replacement, Midframe: 手順 4、 3の画像 1 Motorola Moto G4 Play Side Buttons Replacement, Midframe: 手順 4、 3の画像 2 Motorola Moto G4 Play Side Buttons Replacement, Midframe: 手順 4、 3の画像 3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Side Buttons Replacement: 手順 5、 2の画像 1 Motorola Moto G4 Play Side Buttons Replacement: 手順 5、 2の画像 2
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Side Buttons Replacement: 手順 6、 1の画像 1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Side Buttons Replacement: 手順 7、 3の画像 1 Motorola Moto G4 Play Side Buttons Replacement: 手順 7、 3の画像 2 Motorola Moto G4 Play Side Buttons Replacement: 手順 7、 3の画像 3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Side Buttons Replacement, Side Buttons: 手順 8、 1の画像 1
    • Remove the volume button by pushing the round tips out using the tweezers (or a pen if you don't have tweezers).
  9. Motorola Moto G4 Play Side Buttons Replacement: 手順 9、 1の画像 1
    • Remove the power button by pushing the round tip out using the tweezers (or a pen if you don't have tweezers).
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Francisco Hernández
メンバー登録日: 02/15/18
708 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S17-G4, Boczar Spring 2018 USF Tampa, Team S17-G4, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S17G4
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 20
今までの合計 2,119
