メインコンテンツにスキップ
Motorola Moto G Power (2020) Fingerprint Sensor Replacement
  1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Back Panel: 手順 1、 1の画像 1
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 2、 1の画像 1
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 3、 1の画像 1
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Fingerprint Sensor: 手順 4、 1の画像 1
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 5、 3の画像 1 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 5、 3の画像 2 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 5、 3の画像 3
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 6、 1の画像 1
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: 手順 7、 1の画像 1
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
終わりに
作成者
5人の作成者と共同で作成されました。
Harry Jung
メンバー登録日: 06/23/22
736 ポイント
4のガイドは作成済み
チーム
UC Santa Barbara, Team 1-1, Bator Summer 2022 UC Santa Barbara, Team 1-1, Bator Summer 2022人のメンバー
UCSB-BATOR-SU22S1G1
1 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 634
