はじめに
This guide will show you how to remove the motherboard of your Moto G 3rd Generation. Follow these step for access into the phone's interior. The disassembly requires the use of a heat gun or an iOpener.
ツール
パーツ
パーツは指定されていません。
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
12 の人々がこのガイドを完成させました。
2 件のコメント
My phone is broken inside, it’s not cracked but it did fall off the table i need it fixed
my moto g3 display light problem,this display have no light what can i do
