はじめに
By following this guide, you'll be able to remove and replace the speakers in your Moto G, in the event that they are malfunctioning. This repair is not difficult, but it may take some time, as you have to dig through a few layers to reach the speakers. All you'll need is a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
Using the same screwdriver, remove the six 3.2 mm screws on the sides.
Remove the next layer of the phone by prying it off with your fingers.
On mine, they’re all Torx T5
You neglected to mention that the two buttons might fall out when you remove this part.
Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
Disconnect the battery connector by prying it off of the motherboard.
Disconnect the vibration motor by prying its connector off of the motherboard.
There's no need to remove the battery or motherboard to get to the speakers - they are accessible as soon as the back cover is removed. Skip this step and jump straight to step 10
In fact it is not necessary to remove the simcard rack. I managed to remove battery with the rack on. It is possible to remove the foil startingfrom the bottom of the battery and once peeled off the battery can be removed. You only need to disconnect the battery from the mother board.
Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
As mentioned in a comment on the previous step, you don’t actually need to remove the SIM/SD card reader at all.
If you peel back the copper foil from the opposite end of the device, you can sneak the battery out (and the new battery in) by just sliding the battery ribbon cable out from under the SIM/SD card reader.
Thx for the idea. I’ll let you know if it was working - I’ll my battery soon. regards!
ausssiefan - 返信
Perfect as mentioned - just slide the cable foil under the sim rack - no need to remove the rack. Works flawlessly, quick repair.
Peel off the two black stickers on the right side of the battery using your fingers.
Remove the battery by pulling the right side of it upwards.
If the copper foil is damaged beyond repair, what can be used to replace it?
This is where you will find the two speakers, after you have taken off the motherboard.
With the motherboard off, use tweezers to grab the top speaker.
Remove the speaker and replace it with a new one.
Speaker not working after replacement, what is trick to setting the correct height of the speaker to make proper contact with the spring terminals?
16 の人々がこのガイドを完成させました。
10 件のコメント
Same problem happened to me when I replaced the screen, had to remove the speaker and when I put it back the upper (left) didn't work and the lower (right) had terrible distortion noise. playing a little with the upper speaker location made it work but with noise as well.
The phone is useless without this speaker, it's pretty shame that nobody pays attention to this point in their guides.
Have you fixed your speakers? Did you at least discovered why it happened?
I had a similar problem after replacing my battery. After I put the phone back together, my bottom speaker was not working. I went ahead and ordered a speaker to replace the one that was not working, and it still didn't work. Knowing that my top speaker was working okay, I replaced the top speaker to see if the new one I received was working, and it didn't work on top either. As a matter of fact, I put back the original top speaker that was working okay, and now it doesn't work. So now neither one of them are working. I have to use earphones to hear my phone. I don't know what happened. The instructions to replace the speakers are not that difficult.
Does anyone have any suggestions on what I should do? I'm not ready to give up my phone just yet.
Betsey -
To corroborate with the other commenters: removing the motherboard is unnecessary. The speakers are only held in with a small ring of adhesive, which can easily be pried out. Additionally, the two speakers are identical.
I was having trouble removing the adhesive copper foil above the battery, most of it ripped and is ruined. How much will that affect phone performance?
I had no sound after replacing my screen, but it's kind of working now after footering about, so I thought I'd share my thoughts for anyone in a similar predicament (I'm very much a chancer - happy to be corrected by someone who knows what they're on about!)
It seems like the speakers are connected via conductors on the back panel. I think the reason I had no sound after transferring them (along with everything else) to the new screen assembly was that the clear plastic/adhesive bit on the new thing wasn't thick enough, so the speaker wasn't being pressed against the back panel hard enough to make a good contact. I swapped this in from the old one and hey presto! A bit distorted, but working :)
So when performing Steps 10 and 11, make sure you don't leave a bit of transparent plastic behind - I'm not sure whether this is additional to the adhesive, or whether it's just turned hard in the meantime, but either way, the speaker needs to be at a certain height to work.
I have the same problem as others. After I replaced the display, the speaker don’t work anymore.
I’m buying new one but I need to know, Are the two speakers identical?
Important - remove SIM cards before opening the phone.
Wojciech Dyba - 返信
