はじめに
Follow this guide, and you will be able to replace the front camera in your Moto G, in the event that it breaks or malfunctions. The part itself is simple to remove, but getting to it make take some time and care. You will need a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
この手順で使用する道具:Tweezers$4.99
Use the prying tweezers to remove the front facing camera.
9 の人々がこのガイドを完成させました。
