メインコンテンツにスキップ
Motorola Moto G 1st Generation Front Camera Replacement
必要な工具と部品
  1. Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: 手順 1、 3の画像 1 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: 手順 1、 3の画像 2 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: 手順 1、 3の画像 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Screws: 手順 2、 1の画像 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: 手順 3、 2の画像 1 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: 手順 4、 2の画像 1 Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: 手順 4、 2の画像 2
    • Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
    • You want to pry up the black tab that locks it in place. It may be under a protective sticker.
    • Though the battery is removed in our second photo, it is not required for removing the front camera.
  5. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: 手順 5、 2の画像 1 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Remove the camera from the phone by using the tweezers.
    • To reassemble, follow the steps in reverse.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Radostin Lobodov
メンバー登録日: 10/16/14
2,904 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G7
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 28
今までの合計 1,335
