メインコンテンツにスキップ
Motorola Moto E6 Play Fingerprint Scanner Replacement
必要な工具と部品
  1. Motorola Moto E6 Play Fingerprint Scanner Replacement, Back Cover: 手順 1、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement, Back Cover: 手順 1、 2の画像 2
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    購入する
    • Run the halberd spudger along the edges of the device. The back cover should easily pop off.
    • Gently remove the back cover. Do not pull hard, as it is still connected to the fingerprint scanner inside the phone.
  2. Motorola Moto E6 Play Fingerprint Scanner Replacement, Circuit Board Covers: 手順 2、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement, Circuit Board Covers: 手順 2、 2の画像 2
    • To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
    • One of these ten screws is covered by black tape located at the bottom left corner of the black cover. Peel back the black tape to access this screw.
  3. Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 3、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    $3.99
    購入する
    • With the angled tweezers, remove the black cover to reveal the motherboard underneath.
    • Remove the black piece cover with caution to avoid puncturing the motherboard with the tweezers.
  4. Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 4、 3の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 4、 3の画像 2 Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 4、 3の画像 3
    • The bottom plastic piece covering the daughterboard can be seen by peeling back the tape covering the bottom section of the phone below the battery.
    • To remove the cover, unscrew the six black 3.45 mm Phillips screws holding the cover in place using the Phillips #0 screwdriver.
  5. Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 5、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 5、 2の画像 2
    • Remove the black cover piece using the angled tweezers.
  6. Motorola Moto E6 Play Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 6、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 6、 2の画像 2
    この手順で使用する道具:
    $3.99
    購入する
    • Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
  7. Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 7、 2の画像 1 Motorola Moto E6 Play Fingerprint Scanner Replacement: 手順 7、 2の画像 2
    • Use the angled tweezers to pull up on the two tabs connecting the scanner to the back plastic panel, and disconnect the fingerprint scanner from the back of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Archer Leida
メンバー登録日: 02/04/20
112 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S22-G4, Regan Winter 2020 Cal Poly, Team S22-G4, Regan Winter 2020人のメンバー
CPSU-REGAN-W20S22G4
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 381
