メインコンテンツにスキップ
Motorola Moto E4 Rear Facing Camera Replacement
必要な工具と部品
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 手順 1、 2の画像 1 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 手順 1、 2の画像 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 手順 2、 2の画像 1 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 手順 2、 2の画像 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: 手順 3、 2の画像 1 Motorola Moto E4 Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: 手順 4、 3の画像 1 Motorola Moto E4 Rear Facing Camera Replacement: 手順 4、 3の画像 2 Motorola Moto E4 Rear Facing Camera Replacement: 手順 4、 3の画像 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
終わりに
作成者
5人の作成者と共同で作成されました。
Nate Tjepkema
メンバー登録日: 01/24/19
1,254 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019人のメンバー
CPSU-WHITE-W19S2G4
4 メンバー
22のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 776
