はじめに
Follow this guide to remove and replace a damaged earpiece speaker for the Moto E4 Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
Twist the spudger to release the plastic clip.
Repeat the process for the clip near the top right corner of the phone.
Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
Remove the plastic midframe.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Insert the point of a spudger in the crevice along the right edge of the earpiece speaker.
Gently pry up to loosen the earpiece speaker from its recess.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
ある他の人がこのガイドを完成しました。
2 件のコメント
Hi Arthur,
I just replaced the screen on my Moto E4 Plus - XT1775 and I am now getting static from the ear speaker when in speaker mode.
I tried Safe Mode, but that didn’t change anything.
Any ideas, thoughts, or advice would be greatly appreciated.
Thank you,
George
Hi George,
Does the earpiece sound normal in non-speaker mode? Or does it also not work? I would double-check if the two spring contacts are properly pressing against the pads on the plastic midframe. Make sure that the spring contacts and the pads are clean.
