メインコンテンツにスキップ
Motorola Moto E4 Plus Battery Replacement
必要な工具と部品
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 手順 1、 3の画像 1 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 手順 1、 3の画像 2 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 手順 1、 3の画像 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: 手順 2、 2の画像 1 Motorola Moto E4 Plus Battery Replacement: 手順 2、 2の画像 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Remove the midframe screws: 手順 3、 1の画像 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Battery Replacement, Release the midframe clips: 手順 4、 2の画像 1 Motorola Moto E4 Plus Battery Replacement, Release the midframe clips: 手順 4、 2の画像 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Battery Replacement, Remove the midframe: 手順 5、 2の画像 1 Motorola Moto E4 Plus Battery Replacement, Remove the midframe: 手順 5、 2の画像 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Battery Replacement, Disconnect the battery: 手順 6、 2の画像 1 Motorola Moto E4 Plus Battery Replacement, Disconnect the battery: 手順 6、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 手順 7、 3の画像 1 Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 手順 7、 3の画像 2 Motorola Moto E4 Plus Battery Replacement, Battery adhesives: 手順 7、 3の画像 3
    • If your battery has two black tabs near the bottom corners, the battery is held in place by stretch-release adhesives. If that's the case, follow this guide instead to complete your battery replacement.
    • Before you begin prying, note that the battery is held in place by two adhesive strips.
  8. Motorola Moto E4 Plus Battery Replacement, Loosen the battery: 手順 8、 2の画像 1 Motorola Moto E4 Plus Battery Replacement, Loosen the battery: 手順 8、 2の画像 2
    • Insert an opening pick into the top right edge of the battery.
    • Push the opening pick in carefully until half of the pick is under the battery.
  9. Motorola Moto E4 Plus Battery Replacement: 手順 9、 1の画像 1
    • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol along the right edge of the battery.
    • Tilt the edge up slightly for a minute to allow the isopropyl alcohol to soften the adhesive.
  10. Motorola Moto E4 Plus Battery Replacement: 手順 10、 2の画像 1 Motorola Moto E4 Plus Battery Replacement: 手順 10、 2の画像 2
    • As you slice through the adhesive with the opening pick, try your best not to bend the battery pack. Soft shell lithium-ion batteries are highly susceptible to damage and can ignite when compromised.
    • Insert another opening pick into the right edge, near the first opening pick.
    • Slide the opening pick down along the right edge to loosen the right adhesive strip.
    • If the slicing feels difficult, apply a few more drops of isopropyl alcohol into the edge, wait a minute for it to seep in, and try again.
  11. Motorola Moto E4 Plus Battery Replacement: 手順 11、 1の画像 1
    • Insert an opening pick into the bottom left edge of the battery.
    • Push the opening pick until it is halfway under the battery.
    • Apply isopropyl alcohol along the left edge and let it sit for a minute to weaken the adhesive.
  12. Motorola Moto E4 Plus Battery Replacement: 手順 12、 2の画像 1 Motorola Moto E4 Plus Battery Replacement: 手順 12、 2の画像 2
    • Grasp the battery along the right corners and slowly lift the right edge upwards.
    • If the battery begins to bend significantly, stop and re-apply more isopropyl alcohol to the left adhesive strip.
  13. Motorola Moto E4 Plus Battery Replacement: 手順 13、 1の画像 1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a replacement battery:
    • Remove the old adhesive from the phone frame.
    • Apply new adhesive in the same general area as the old adhesive.
    • Lay the battery lightly in place. Check that the battery connector is properly aligned with its motherboard socket.
    • Press the battery firmly into the phone for thirty seconds.
終わりに
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
249,815 ポイント
503のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,731のガイドは作成済み
コメント 1 件
You are a star. Spot on. I very much appreciate your contribution in breaking the monopoly of the bastards. They sold me the mobile without telling me the battery is fixed. I was about to send it for repair on their lab which could have cost me at least £200 if not more. £25 DHL . £45 just for looking into it . This is even before replacing the battery and the cost of labor. Take off my hat for you. Keep up the good work.
best regards
Sburgess
SALWAN BURGESS - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 38
今までの合計 4,432
