メインコンテンツにスキップ
Motorola Moto E Volume and Power Buttons Replacement
必要な工具と部品
  1. Motorola Moto E Volume and Power Buttons Replacement, Motherboard: 手順 1、 1の画像 1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Volume and Power Buttons Replacement: 手順 2、 1の画像 1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Volume and Power Buttons Replacement: 手順 3、 1の画像 1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Volume and Power Buttons Replacement: 手順 4、 1の画像 1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Volume and Power Buttons Replacement: 手順 5、 1の画像 1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Volume and Power Buttons Replacement: 手順 6、 1の画像 1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Volume and Power Buttons Replacement: 手順 7、 1の画像 1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Volume and Power Buttons Replacement: 手順 8、 2の画像 1 Motorola Moto E Volume and Power Buttons Replacement: 手順 8、 2の画像 2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Volume and Power Buttons Replacement: 手順 9、 1の画像 1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Volume and Power Buttons Replacement, Volume and Power Buttons: 手順 10、 1の画像 1
    • Locate the 3 tabs on the backs of the volume and power buttons.
    • Press firmly on the tabs using the plastic spudger until they pop out.
  11. Motorola Moto E Volume and Power Buttons Replacement: 手順 11、 1の画像 1
    • Press the new buttons into the assemblies.
    • Be sure the new buttons are facing the correct direction. The outside of the button should match the shape of the hole.
終わりに
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alex Craig
メンバー登録日: 03/11/15
2,596 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G7
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 47
今までの合計 22,602
