メインコンテンツにスキップ
Motorola Moto E 2nd Generation Display Assembly Replacement
必要な工具と部品
  1. Motorola Moto E 2nd Generation Display Assembly Replacement, Display Assembly: 手順 1、 1の画像 1
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 2、 3の画像 1 Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 2、 3の画像 2 Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 2、 3の画像 3
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
  3. Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 3、 3の画像 1 Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 3、 3の画像 2 Motorola Moto E 2nd Generation Display Assembly Replacement: 手順 3、 3の画像 3
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
終わりに
37 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andre Romualdo
メンバー登録日: 02/08/16
3,765 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 12-3, Eyestone Spring 2016 USF Tampa, Team 12-3, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S12G3
3 メンバー
14のガイドは作成済み
5 件のコメント
Will the glue work againg when reassambling?
Rodolfo Coss - 返信
Rodolfo, no - the glue cannot be reused during reassembly. There should be a step 4.
Step 4: enclosed you will find a rectangle of double-sided adhesive. Use scissors/knife to trim off thin strips of adhesive, and place these around the edge of the housing where the glue was previously bonded (remove any residual glue from the housing before placing the adhesive).
You can get the gist of it by watching from 9:52 on this youtube video on replacing a Moto G screen (different phone, same principle): https://www.youtube.com/watch?v=zdRJsQUl...
Now reverse the first 3 steps.
Mark Eldridge - 返信
what if the black strip behind display get torn off while lifting the screen?
kalpitmairh - 返信
Hi Andre, when you say “enclosed “ (in response to Rodolfo’s question, enclosed where?
Newby - 返信
Just a heads up:
If you replace the screen, make sure to transfer the plastic ear piece from the original screen to the replacement. (It’s the one with the metal bar) I was unable to find a replacement through any of the suppliers I use.
J.K - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 19
今までの合計 15,239
